Wiring question 1965 factory air 327/350 - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 215
    IMG_3963.jpgIMG_3962.jpgIMG_3962.jpgIMG_3962.jpgI'm wading through wiring issues , upside down after removing radio to facilitate clock repair. Clock works fine- but I notice now that high beams work, low beams do not.<br />
    After sifting through wiring diagrams in shop manual-well I'm trying to indentify the plug and harness seen in the photos. I'm not seeing any obvious male side.<br />
    The wires are black/orange , black/yellow, black /white, black/orange
  • Mark M.
    • October 21, 2008
    • 340
    Re: Wiring question 1965 factory air 327/350
    That looks like the fan switch connector. It should plug into the switch above the radio, below the clock on the driver side.
    • Joseph S.
      National Judging Chairman
      • March 1, 1985
      • 868
      John, If you had a heater only car, that would plug into the back side of the heater switch. When the 1963-67 A/C option is added, an additional wiring harness for the A/C system is added to the car. That connector along with the other end of that set of wires is not used and is just left tucked away.
      • James W.
        • December 1, 1990
        • 2655
        In the picture I attached you can just see the wiring connection you are referring to. As Joe stated, it is was taped into the wiring loom on A/C equipped cars. This is my '65, 327/350 equipped with A/C.
        James
