61 aluminum radiator repair - NCRS Discussion Boards
  • Richard F.
    Infrequent User
    • July 31, 1992
    • 11
    I have a 61 with an aluminum radiator that is clean and does not need replacing. Recently it has developed some pinhole leaks in the radiator itself (coolant not yet hitting garage floor). Short of a new Dewitts replacement, I'm looking for a "stop leak" product that could seal these small holes, but without the fear that the cooling system would become restricted and/or blocked like Barrs Leak allegedly does. Any thoughts.............
  • Dale E.
    Infrequent User
    • May 31, 1988
    • 9
    Re: 61 aluminum radiator repair
    GM has a stop leak product, a packet of 3 pellets that I have heard works well. Naturally I don't have a part number, sorry
    • Jim L.
      • September 30, 1979
      • 1816
      If the radiator is "thin" in some obvious areas, it's almost certainly "thin" in other areas. IMHO, you would be well served by biting the bullet and ordering a new DeWitt radiator instead of trying to bandaid the one you have.
      • Terry D.
        • May 31, 1987
        • 2696
        Agree with Jim, very doubtful that is the only bad area. With a new one you won't have to worry that it might spring a big leak going down the road!
          • 43259
          Jim and Richard-----
          I also agree. I would not even attempt to repair a 63 year old aluminum radiator if I planned to drive the car. DeWitts reproduction is the only way to go. And, be thankful that the DeWitts is available. I never though that any of these 1960-72 aluminum radiators would ever be reproduced (until Tom DeWitt came around).
            • 15706
            It's likely just Bar's Leaks in a GM package. Bar's Leak's in liquid or tablet form should be available at any auto parts store.
            • Tim S.
              • May 31, 1990
              • 713
              Write the check and cry once. Dewitts has a promotion right now.......I have bought 4 of them this last week
              • Leif A.
                • August 31, 1997
                • 3646
                Leif
