Distributor 1110914 ? - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2053
    Does the 1110914 distributor have a vacuum advance or just mechanical?
    Used on a 7320 FI unit.
    • 43273
    Re: Distributor 1110914 ?
    Alan-----
    No vacuum advance was used on the 1110914 distributor.
      • 15706
      According to the NCRS Spec, Guide the ...914 distributor was used on mid-'58 to '61 290 and 315 HP FI engines, and those are the versions with a Duntov mechanical lifter cam, so that should be a dual-point, non-VAC distributor.'
      The 1110915 distributor was used on 58 to 61 250 and 275 HP FI engines that have the base engine hydraulic cam, and that should be a single point, VAC distributor.
      • Alan D.
        • January 1, 2005
        • 2053
        Thank you ! And I should have followed my own rule about searching before posting - sorry.
        And also got my next ? answered also on the 1110915 distributor - thanks
