C2 Headlight open control switch - NCRS Discussion Boards
+ More Options
Posts
  • Ron S.
    • January 1, 1992
    • 42
    I have the original switch from my 66, would like to sell but want to ensure it works properly. I don't have my car anymore; can I test somehow with a multimeter? Thanks in advance!
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: C2 Headlight open control switch
    I assume you are talking about the up/dn switch inside the car......
    It will have 3 poles (connection points) Using an Ohm meter, with the switch "at rest" the circuits will be open. Push the switch to "up" and you should see continuity between 2 of the poles. Push the switch to "dn" and you should see continuity between the 3rd pole and the common pole.
    • Ron S.
      • January 1, 1992
      • 42
      Stephen, you are correct. Just checked and switch is functioning properly. Can't seem to remember why I replaced (But that was 25+ years ago!). I have it on Marketplace if anyone is looking for one. Thanks for your help!!
      Ron
      • Rich G.
        • August 31, 2002
        • 1397
        Just because it has continuity doesnโ€™t necessarily mean itโ€™s ok. Contacts could be burned and not work when attempting to switch the high current required to move the motors. Or maybe not.
        Hope it works out.
        Rich.
        • Ron S.
          • January 1, 1992
          • 42
          Hi Rich, never considered that. Could be why I replaced it many years ago. Are these switches serviceable? I noticed on eBay there are a lot of just switch housings. Are you aware of any Tech Article detailing taking one of these apart and refurbishing?
          Thanks!
          Ron
          • Ron S.
            • January 1, 1992
            • 42
            Never mind Rich, found article in Fall 2007 Restorer re switch repair
            Ron
            • Rich G.
              • August 31, 2002
              • 1397
