66 427 fan shroud question - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 306
    i am looking to see if someone can provide me with the correct location on the 2 holes for the clips that retain the overflow hose on the side of the shroud , and also the size of the small hole at the bottom of the shroud. I have been thru old posts and a 1/8 hole has been mentioned but in the pictures i have seen it looks more like 1/4". Any info on both question's would be great
    thanks Bob Peckham #66450
  • Mark M.
    • October 21, 2008
    • 340
    Re: 66 427 fan shroud question
    Bob check out some pictures I posted in 2020 under 66-67 427 radiator shroud . Post #48 should help
    • Robert P.
      • October 19, 2019
      • 306
      Mark i did read that whole thread a few times , i can roughly figure out the holes by the picture and i am not certain that they where the same on all fan shrouds , was hoping someone had one out that could measure one
      Bob
      • Mark M.
        • October 21, 2008
        • 340
        Bob I checked a few original 66 and 67s and all have the same holes. From the bottom up the first hole is 15/16" to it's center , the top hole is 7 1/2" c/c from the bottom hole, leaving 7/8" from the top to top hole center. From the outside of the 90* bend measuring to center of hole they are 3/4" inward (left). The two holes are 17/64" dia. The hole on the bottom of the 66 shrouds are 1/4". Hope this helps. Mark
        • Robert P.
          • October 19, 2019
          • 306
          thank you very much for the info greatly appreciated
          Bob
