c2 door panels - NCRS Discussion Boards
c2 door panels
  • Steve C.
    • June 1, 2021
    • 35
    c2 door panels
    does anyone have any gouge on locating the 1/4 -20 screws underneath the armrests to the nut plate behind the door panel ??
    i pulled whats left of my hair out installing new panels from al knoch.. not their fault but it's tuff trying to locate these screws at the
    proper angle to basically a blind hole..
    thanks
    65 roadster
  • Bruce W.
    • June 30, 1997
    • 360
    Re: c2 door panels
    should be able to get those from any vender. Try zipp corvette
    Bruce
    • Mark F.
      • July 31, 1998
      • 1572
      Re: c2 door panels
      Originally posted by Steve Chaney (68070)
      does anyone have any gouge on locating the 1/4 -20 screws underneath the armrests to the nut plate behind the door panel ?? i pulled whats left of my hair out installing new panels from al knoch.. not their fault but it's tuff trying to locate these screws at the proper angle to basically a blind hole.. thanks 65 roadster
      Maybe use a long icepick to locate the hole; and then note the position of the icepick shaft and try to replicate that with the bolt ?
      thx,
      Mark
        • 6950
        Re: c2 door panels
        Steve, I wonder if you could take a 1/4 20 screw and grind a point and thread into nut plate I would try making a short screw so the panel can lay flat as possible a d that should mark location.you could even use a dab of grease to help mark.
        • Steve C.
          • June 1, 2021
          • 35
          Re: c2 door panels
          thanks edward...great idea... that would definitely lower the risk of cross threading.. i had my 1/4 -20 tap and die handy when i did them. and had
          to use them a time or three whilst in the process..
          • Steve C.
            • June 1, 2021
            • 35
            Re: c2 door panels
            thanks bruce
            • Steve C.
              • June 1, 2021
              • 35
              Re: c2 door panels
              thanks mark...
              • David Z.
                • April 1, 2002
                • 182
                Re: c2 door panels
                Not a template but here's some pics/info for the door panels on our '65. PDF attached.
                Dave Z
                Dave Zuberer
                • Steve C.
                  • June 1, 2021
                  • 35
                  Re: c2 door panels
                  thank you dave..awesome pics.. nice template
                  • Steve C.
                    • June 1, 2021
                    • 35
                    Re: c2 door panels
                    thanks to all for your suggestions. i was able to get the panels installed in time for a car show Oct 19th.
                    a great day
