Distributor Applications Data References - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11360
    I captured these as HTML files years ago that I've had stored for many years. I'm putting them here for future reference. It came from corvettemagazine.com digital format. It's title was: "Name That Distributor" by Alan Colvin. It was a article describing the different distributor applications.
    Note that it may not format perfectly as I merely did many copy/pastes to get it here in this thread. I was unable to get separate images in the article as I couldn.t retrieve them at the time.
    Note that there were no 1956 or 1957 reference pages.
    I added reference to this thread in the Database of Restoration Documents Sticky..... UPDATE Page.
    Rich
    The Delco-Remy Division of General Motors in Anderson, Indiana manufactured all Corvette distributors from 1955 through 1982. There were two plants involved in producing ignition components at Delco-Remy. Plant 10: All conventional (point-type) distributors and ignition coils were built at Plant number ten while all ignition amplifiers and capacitor discharge ignition systems were assembled at Plant number six. All HEI ignition systems and the newly developed (late model) Direct Ignition Systems were assembled at Plant number twenty.
    Delco built a variety of distributor component combinations that were used from 1955 through 1982. All distributors were of cast iron construction until 1962 when the die-cast aluminum 4- and 6-cylinder models were released. There were "Bowl" and "Non-Bowl" distributors produced in both aluminum and cast iron. Early distributors had an external oiler tube for routine lubrication. There were also "Bowl" type cast iron units that had special two-piece housings with dual-point breakers inside the distributor. Because of the numerous combinations that are possible, please see the distributor application list for your specific application. We do know some specific combinations used for Corvettes. For example, all Corvette distributors produced from 1955 through 1974 were cast iron and all were equipped with tach drive from 1962 through 1974. In 1975, all GM cars, including the Corvette, went to the HEI ignition.
    Distributor Model Number and Date Codes
    All Delco-Remy distributors have a model number and a date code system either stamped or attached to the distributor. There are four basic locations in which this information can be found which vary from distributor to distributor. On all 1955-56 distributors, the model number is found on an oval Delco-Remy tag riveted to the outside of the distributor housing. In the 1957 model year, the identification process began to change. From 1957 through 1974 all cast iron non dual-point distributors used a small aluminum band, which wrapped around the top of the distributor. All 1957 through 1961 dual-point distributors used the oval Delco-Remy riveted tag. This band was imprinted with the model number and production date. Fuel injection distributors from 1957 to mid-1958 used a Delco tag identical to other distributors. Starting in mid-1958, the fuel injection distributor was redesigned and was produced with a square tag that was held to the main distributor housing by four screws. Late model aluminum distributor housings have the model number roll stamped right into the exterior of the housing with no attaching tag of any kind. Date code stamps are near the model number. The location varies from year to year. On early distributors with a riveted metal tag, the date code is above the word "Serial."
    Date Code Deciphering
    All Chevrolet distributors use the same Julian code system date code style. The actual build date is signified by a series of numbers and letters. Example: 5A28. The date code is deciphered as follows:
    The first digit gives the calendar year of production. This is the last digit of the calendar year, 1955 in the example above. The second letter indicates the month of production. See the table below for month codes. ("I" was not used because it is too easily confused with the number 1.) The final two digits indicate the day of the month of production (1 through 31). The code 5A28 therefore decodes as january 28, 1955.
    Distributor Color Coding
    Most distributors installed at a final engine assembly plant had a color code applied to the distributor housing. This was to enable engine assemblers to identify a distributor without reading the code number. In time, many of these paint marks wore off. Most Delco Remy blueprints call out these color codes as paint spots.
    The charts on the following pages list the distributor applications for 1955-1975. All distributors are in numerical order within each model listing. Each distributor is listed by model and engine, and then further distinguished by housing type, point type and other features. Be sure to check the model years before and after your car to check for other uses. The abbreviations used in the charts are listed below.
    Housing Type Designations
    A: Aluminum housing distributor
    AE: Aluminum external adjustment distributor
    CB: Cast iron bowl distributor
    CE: Cast iron external adjustment distributor
    2: Two-piece housing
    Point Type Designations
    D: Dual-point distributor
    MP: Magnetic pulse distributor
    S: Single point distributor
    HEI: High energy ignition
    EMC: Distributor model containing a uniset contact set designed for radio suppression
    Letter Designations
    CL: Cam lubricator mounted on breaker plate
    CO: Copper standpipe oiler
    EO: Engine oil lubrication distributor
    FI: Fuel injection distributor
    FT: Fuel injection distributor with tach drive
    LW: Lead wire (with color code)
    NO: No standpipe oiler
    NV: No vacuum advance
    PL: Permanent lubrication
    RB: Red identification band
    SB: Square box on distributor shaft
    SO: Standpipe oiler (standard)
    TD: Tach drive/flexible cable drive
    V: Vacuum advance
    ECC: Electro-magnetically Compatible Contact
    RFI: Radio frequency interference shield installed
    Color Code Designations
    1: No Paint 2: White 3: Yellow 4: Orange 5: Pink 6: Red 7: Light blue 8: Blue 9: Light green 10:Green 11: Gray 12: Brown 13: Black 14: Purple
    Abbreviations
    A.I.R.: Air Injection Reactor
    A/T: Automatic Transmission
    CD: Capacitor Discharge
    HP: Horsepower
    S/T: Standard Transmission
    TI: Transistorized Ignition
    If the distributor color coding from the factory is known, the color code will show last in the remarks column under that distributor. If no number shows up after the last letter code in the remarks column, no color code is known for that distributor
    1958 Distributor Applications
    Model Distributor Number Engine/HP/Application Housing Point Notes
    Corvette 1110890 283/230HP All CE S CL/SO/V
    1110891 283/245, 270HP All CB D NV/SO
    1110906 283/250HP All (Early) CB/2 S BB/EO/FI/PL/V
    1110908 283/290 HP (Early) (Unverified)* CB/2 D BB/EO/FT/NV/PL/TD
    1110914 283/290 HP CE/2 D EO/FT/NV/TD
    1110915 283/250 HP All (Late) CE/2 S FI/SO/V
    *Delco-Remy records show that no #1110908 distributors were built for production for the 1958 calendar year.
    1959 Distributor Applications
    Corvette 1110891 283/245, 270HP CB D NV/SO
    1110915 283/250HP All CE/2 S FI/SO/V
    1110946 283/230HP All CE S CL/SO/V
    *Late Production
    1960 Distributor Applications
    1110914 283/290, 315HP CE/2 D EO/FT/NV/TD
    1110915 283/250, 275HP All CE/2 S FI/SO/V
    1961 Distributor Applications
    1110914 283/315HP CE/2 D EO/FT/NV/TD
    1110915 283/275HP CE/2 S FI/SO/TD/V
    1962 Distributor Applications
    Corvette 1110984 327/250, 300HP All CE S CL/SO/TD/V
    1110985 327/340HP CE D CL/NV/SO/TD
    1110990 327/360HP (1st Design) CE/2 D EO/NV/TD
    1111011 327/360HP (2nd Design) CE/2 D NO/NV/TD
    *#1111023 was definitely used as the 2nd design 409 distributor for 1962. Delco-Remy documentation shows that #1111006 was not produced, but this has not been verified.
    **These engines were produced at the Flint Engine Plant for Chevrolet Service conversion purposes only. Although they were assigned an identifying suffix code, none were installed at a final assembly plant until the 1964 model year, when the 283 engine became available as an R.P.O. (Regular Production Option).
    1963 Distributor Applications
    Corvette 1111022 327/360HP All CE/2 S CL/FT/NO/PL/SB/V
    1111024 327/250, 300, 340HP All CE S NO/TD/V
    1964 Distributor Applications
    Corvette 1111024 327/250, 300HP All CE S NO/TD/V/1
    1111060 327/365HP CE MP TD/V/2-10LW
    1111062 327/365HP (1st Design, unverified) CE S TD/V
    1111063 327/375HP (1st Design) CE/2 S SB/TD/V
    1111064 327/375HP (Unverified) CE/2 MP SB/TD/V/2-10LW
    1111069 327/365HP (2nd Design) CE S RB/TD/V
    1111070 327/375HP (2nd Design) CE S NO/SB/V/1
    *These engines were produced at the Flint Engine Plant for Chevrolet Service conversion purposes only. Although they were assigned an identifying suffix code, no record has been found that they were installed at a final assembly plant.
    1965 Distributor Applications
    Corvette 1111060 327/365HP CE MP RB/TD/V
    1111064 327/375HP CE/2 MP SB/TD/LW 2-10/V
    1111069 327/365HP All CE S RB/TD/V
    1111070 327/375HP All CE/2 S SB/TD/V
    1111076 327/250, 300HP All CE S TD/V
    1111087 327/350HP All CE S RB/TD/3/V
    1111088 327/350HP CE MP RB/TD/LW 2-10/3/V
    1111093 396/425HP CE MP TD/LW 2-10/4 (2 aft. 12/64)
    1966 Distributor Applications
    Corvette 1111087 327/350HP 1st Design CE S RB/TD/3/V
    1111093 427/425HP CE MP TD/LW 2-10/2/V
    1111117 327/300HP A.I.R. CE S TD/10/V
    1111141 427/390HP All CE S TD/14/V
    1111142 427/390HP CE MP TD/LW 2-10/14/V
    1111153 327/300HP W/O A.I.R. CE S TD/10/V
    1111156 327/350HP 2nd Design CE S TD/3/V
    1111157 327/350HP 2nd Design CE MP TD/LW 2-10/3/V
    1111196 327/350HP 3rd Design CE S TD/V
    1967 Distributor Applications
    Corvette 1111117* 327/350HP A.I.R. CE S TD/10/V
    1111157 327/350HP CE MP TD/LW 2-10/3/V
    1111194 327/300HP All CE S TD/10/V
    1111196 327/350HP All CE S TD/3/V
    1111240** 427/430HP L88 CE MP TD/LW 2-10/2/V
    1111247*** 427/390, 400HP All CE S TD/14/V
    1111248 427/390, 400HP CE MP TD/LW 2-10/14/V
    1111258 427/435HP CE MP TD/LW 2-10/2/RB/V
    1111294 (Released 2/3/67) 427/390, 400HP (unverified) CE MP TD/LW 2-10/V
    * Some sources state that distributor #1111117 applied to the 327/300HP Powerglide Transmission. This has not been verified to date.
    ** Brown cap until 5/74, then black cap. Special vacuum unit assembly.
    ***Some sources state that the following 1966 distributors were used on 1967 models:
    #1111109 was used in place of #1111169 on approximately 700 passenger cars (except RPO K19);
    #1111112 and #1111138 (1700 and 390 distributors respectively) were used in place of #1111170 on 396/350HP Chevelles (exc. RPO K19);
    #1111141 was used in place of #1111247 on approximately 390 Corvettes (except RPO K19).
    1968 Distributor Applications
    Corvette 1111194 327/300HP All CE S TD/10/V
    1111293 427/390, 400HP All CE S TD/14/V
    1111294 427/390, 400HP CE MP TD/1/V
    1111295* 427/430HP L88 CE MP TD/LW 2-10/2/V
    1111296 427/435HP CE MP TD/LW 2-10/2/RB/V
    1111438 327/350HP All 1st Design CE S TD/1/V
    1111441 327/350HP 1st Design CE MP TD/LW 2-10/3/V
    1111475 327/350HP 2nd Design CE MP TD/LW 2-10/4/V
    1111477 327/350HP All 2nd Design CE S TD/4/V
    *Brown cap, special vacuum unit assembly
    1969 Distributor Applications
    Corvette 1111490 350/300HP All CE S TD/10/V
    1111491 350/350HP CE MP TD/4/LW 2-10/V
    1111493 350/350HP All (Unverified) CE S TD/4/V
    1111926 427/390, 400HP All CE S TD/V
    1111927 427/430HP L88, ZL1 CE MP TD/LW 2-10/2 (special vacuum unit)
    1111928 427/435HP CE MP TD/LW 2-10/V
    1111954 427/390, 400HP C MP TD/LW 2-10/14/V
    1970 Distributor Applications
    Corvette 1111464 454/390HP All CE S TD/11/V
    1111490 350/300HP (Early) All (unverified) CE S TD/10/V
    1111493 350/350HP (Early) All (unverified) CE S TD/4/V
    1111496 350/370HP All CE S TD/V
    1111971 350/370HP CE MP TD/LW 2-10/V
    1112020 350/300HP All CE S RFI/TD/10/V
    1112021 350/350HP All CE S RFI/TD/4/V
    1971 Distributor Applications
    Corvette 1112038 350/270HP CE MP TD/3/LW 2-10/V
    1112050 350/270HP All CE S/EMC TD/10/V
    1112051 454/365HP All CE S/EMC TD/11/V
    1112053 454/425HP, A/T CE MP TD/5/LW 2-10/V
    1112076 454/425HP, 4-Speed CE MP TD/14/LW 2-10/V
    1972 Distributor Applications
    Corvette 1112050 350/200HP All CE S/EMC TD/10/V
    1112051 454/270HP All CE S/EMC TD/11/V
    1112101 350/255HP LT1 All CE S/EMC TD/3/V
    1112165 350/200HP 2nd Design CE S/EMC TD/10/ECC/V
    1112167 350/255HP LT1 All 2nd Design CE S/EMC TD/3/ECC/V
    1112169 454/270HP All 2nd Design CE S/EMC TD/11/V
    1973 Distributor Applications
    Corvette 1112098 350/190HP All CE S TD/10/V
    1112114 454/245HP All CE S/EMC (Aft. 7/73) TD/RFI/11/V
    1112150 350/250HP L82 All CE S/EMC (Aft. 7/73) TD/RFI/5 (7 after 4/73
    1974 Distributor Applications
    Corvette 1112150 350/250HP L82 All CE S/EMC (Aft. 7/73) RFI/TD/7/V
    1112247 350/195HP All exc. CA, S/T CE S TD/2/V
    1112526 454/270HP All CE S TD/10/V
    1112544 350/195HP S/T CA CE S TD/4/V
    1975 Distributor Applications
    Corvette 1112880 350/165HP All CA A HEI 13/V
    1112883 350/205HP L82 All 1st Design A HEI 7/V
    1112888 350/165HP All exc. CA A HEI 8-8/V
    1112979 350/205HP L82 All 2nd Design A HEI 9/V
    1976 Distributor Applications
    Corvette 1103200 350/210HP All A HEI 10/V
    1112888 350/180HP All exc. CA A HEI 8(2)/V
    1112905 350/180HP A/T CA A HEI 10-4/V
    1977 Distributor Applications
    Corvette 1103246 350/180HP exc. CA A HEI 13/V
    1103248 350/180HP A/T CA A HEI 3/V
    1103256 350/210HP All A HEI 10/V
    1978 Distributor Applications
    Corvette 1103285 350/17HP A/T CA A HEI 3-10/V
    1103291 350/220HP All A HEI 10/V
    1103337 350/185HP All A HEI 6-13/V
    1103353 350/175HP A/T HA A HEI 3/V
    350/185HP A/T (Cut engine code only)
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11360
    Re: Distributor Applications Data References
    Thanks David, for some reason my files are missing those years.
    Rich
    • David H.
      • June 30, 2001
      • 1559
      Richard
      Trying to get a more readable post.
      Dave
