I finally gave up on my front right turn signal failure. I just replaced the turn signal switch. New from electric limited. Signals all work great. But my horn is now energized I had to pull connector off of the relay. I checked my steering re assembly and all looks right. Any ideas ? Thanks
Turn signal
Re: Turn signal
I finally gave up on my front right turn signal failure. I just replaced the turn signal switch. New from electric limited. Signals all work great. But my horn is now energized I had to pull connector off of the relay. I checked my steering re assembly and all looks right. Any ideas ? ThanksNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
