1990 blower motor control module - NCRS Discussion Boards
  • E B.
    • March 1, 1978
    • 127
    • 6961
    Re: 1990 blower motor control module
    EJ, have you tried to google that part number? You may come up with something, maybe EBay. I had a 97 that had the same problem at one time. You may also find someone that can rebuild the module?? A lot of time the circuit boards have mini relays that are problematic.
      • 43297
      Originally posted by E J Bauscher (1814)
      The blower run on high with ignition key is off or on. Seems the module is faulty and origional Delco 16061602 is not available. Is there a replacement ? I’ve owned this car since 1996.
      EJ----
      Auto ECM's (autoecms.com) has that module available in remanufactured form. It has other applications besides Corvette.
        • 43297
        EJ------
        I did a little more research on this one and I cannot find that GM #16061602 was ever a SERVICE part number. I realize that this is the number that appears on the part but it must be either a non-SERVICED component of the module or a PRODUCTION only part number.
        The current GM part number for the module is 12368387, aka ACDelco #15-71642. About 150 bucks.
        • E B.
          • March 1, 1978
          • 127
          I thank all of your replies. I know it takes a lot of time to research this issue. Tried on my own but it seems like chasing my tail on this one.
          thanks again for helping me out. Ed
          • E B.
            • March 1, 1978
            • 127
            Update on source of compatible control module. 93-96 jeep grand Cherokee available from Amazon $23.70 p/n 4720046 4p1721 by Geluoxi
            made in China ( my origional made in Japan ). Installed it yesterday and works fine. Hope this helps.
