1963 coupe rear window installation tips- tricks ? - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 803
    Anyone have any tips or tricks to this install? I have Corvette Rubber w\ strip nos clips and Keen Corvette longer clips. Thanks Bob
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 927
    Re: 1963 coupe rear window installation tips- tricks ?
    Bob, I've done all of my coupes with the stock length clips. I usually add a few more near the corners since that is where you typically run into issues.
    Good luck.
    • Bob W.
      • December 1, 1977
      • 803
      Joe, Thank you for your reply. Did you use original or reproduction weatherstrips ? Also on the back side of the molding where it clips on how far in did you place the clips? Thanks again Bob
      • Joseph S.
        • March 1, 1985
        • 927
        Bob, I get my rubber from Corvette Central. There should be small indicators on the body for where the clips go. If someone sanded them off check the AIM for positions. I add an extra at the roof curve and at the rear deck curve. Those area are always trouble.
        Good luck.
        • Bob W.
          • December 1, 1977
          • 803
          Joe, Thanks again. Yes some of the indicators were sanded off . I do have a AIM so I will look at it . Can I call you if I need more info if so when is a good time?
          Thanks again Bob
          • Joseph S.
            • March 1, 1985
            • 927
            Bob, Call anytime. My phone number is listed on the NCRS contacts page. I'm more than happy to help.
            Joe
            • Bob W.
              • December 1, 1977
              • 803
              Joe, Thanks again, this is why the NCRS is the best club to be a member of.
              Bob
