Transmission ID - NCRS Discussion Boards
Transmission ID
  • Sven C.
    • July 18, 2015
    • 188
    Transmission ID
    This transmission was removed from an early 1966 car, but it clearly came from a very late 1966 based on the vin number stamped on it. I believe it is a Muncie wide ratio M20 and just looking to see if the transmission experts out there agree with me. Pics attached.
    I was hoping to reunite the transmission with the car and I checked the C-2 Registry to try to locate the car, but no luck. This makes me think that this transmission may have been removed from a wrecked car and put in the early car. Is there another way to try to see if the car is out there? I was thinking about putting it in the NCRS "Orphan Documents and Stamped Parts", but if it was probably wrecked, why bother.
    Any suggestions are appreciated.
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 Ontario NCRS Regional Meet (Regional) at 09-14-2023
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 National Convention-French Lick (National) at 07-27-2023
    1963 Corvette: Flight Judging Award (Top Flight) at NCRS Indiana Regional (Regional) at 04-28-2022
    1963 Corvette: Flight Judging Award (Top Flight) at Ontario Chapter judging Meet 2021 (Chapter) at 09-18-2021
  • Dan A.
    • May 31, 1974
    • 1073
    Re: Transmission ID
    Assuming Bubba has not been there the 3870354 part number tag is an M20 or wide ratio for 1966-7.
    • Sven C.
      • July 18, 2015
      • 188
      Re: Transmission ID
      Thanks Dan. Also found that an M20 has two cuts across the 10 input shaft splines, so I am sure it is a Muncie M20 wide ratio.
      • Ronald L.
        • October 18, 2009
        • 3248
        Re: Transmission ID
        the first thing bubba does is take the pn tag and use same for hinge shim so probably unmolested
        • Sven C.
          • July 18, 2015
          • 188
          Re: Transmission ID
          Thanks Ron. That's what I hope. Listed it in the C2 orphaned parts, so hoping it might be out there.
          • Ronald L.
            • October 18, 2009
            • 3248
            Re: Transmission ID
            Post on CF and gooogle the vin from time to time to see if the car comes up for sale
