C1 front steering and suspension interchangeability - NCRS Discussion Boards
  • Tim M.
    Infrequent User
    • July 14, 2012
    • 29
    Will all years of C1 Corvette front suspension and steering parts interchange with each other regardless of casting # or year made? As an example will a 1954 Corvette pitman arm fit and work correctly on a 1962 Corvette? Will a 1954 Corvette 3rd arm bracket work correctly with a 1958 3rd arm? Will a whole 1961 front suspension unit bolt in to a 1954 Corvette?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17916
    Re: C1 front steering and suspension interchangeability
    Tim,
    Tom Parson (3491) would be the best source to answer the question on C1 interchangeability.
    in 1956 Zora added shims, change idler & 3rd arm etc. to improve stability above 60 mph - see attached TSB267.
    In 1956-57 there were multiple 3rd arms; cast part #3706023, 3706024, 3727511 & 3742688. IIRC 1958-62 were cast # 3742688.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
