Numbers on Muncie Transmission - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 821
    Just checking numbers on an LT1 I bought. The side cover is 3952648. Tail 3978764, Main 3925661. I think it is an M21. Has anyone seen a code like this photo? Perhaps a rebuild number? Says CCI 3790 and then what looks like a reverse S. Doesn't like original was ground off but maybe
    • 43242
    Re: Numbers on Muncie Transmission
    Bob----
    If there is no VIN derivative stamped on the case, then this is likely a SERVICE replacement main case.
    • Patrick B.
      • August 31, 1985
      • 2000
      I have a 67 service case that has nothing stamped on it, but I have seen the CC1 mark on later cases. It must be just a service case because a whole service trans would have the Muncie date stamp but no vin.
      • Gerald C.
        • June 30, 1987
        • 1294
        I have a Muncie that I'm trying to identify:
        Front Spline 10
        Rear Spline 27
        Case # 3885010
        Tailshaft #3857584
        Cover #3885685
        The number stamped on the side appears to be 7S112066
        Thanks for the feedback
          • 43242
          Gerald-----
          Sidecover casting number should be 3884685.
          This transmission is a 1967 Muncie. I cannot determine if close or wide ratio from information provided. It may be possible to determine by the number of circumferential grooves on the mainshaft splined section providing that the mainshaft has not been replaced at some point with aftermarket.
          • Gerald C.
            • June 30, 1987
            • 1294
            Gerald-----
            Joe,
            Sorry, you are correct about the side cover. I forgot to put the "4" in my description. The front spline does have 10 splines in it.
            • Mark F.
              • July 31, 1998
              • 1555
              Gerald,
              There should also be an assembly code stamped into it.
              for a '67 Muncie 4-speed it should read:
              P = 4 speed Muncie
              7 = 1967
              a letter indicating the month (page 194 of the TIMJG has those unique codes), and
              two digits indicating the day of the month
              thx,
              Mark
                • 43242
                Originally posted by Gerald Coia (11656)
                Joe,
                Gerald-----
                Yes, I understood the mainshaft had 10 splines. However, the 1st gear ratio may be determinable by the number of CIRCUMFERENTIAL GROOVES on the splined portion of the shaft.
                • Mark F.
                  • July 31, 1998
                  • 1555
                  This site has a Muncie transmission ID and ratio guide chart:
                  http://www.dandltransmission.com/muncieratio.html
                  thx,
                  Mark
                  • Gerald C.
                    • June 30, 1987
                    • 1294
                    Gerald-----
                    Joe, Here are a few pictures of the tranny which I should have included in the first place.
                    • Gerald C.
                      • June 30, 1987
                      • 1294
                      Thanks! Much appreciated
                      • Mark F.
                        • July 31, 1998
                        • 1555
                        Hey Gerald,
                        is that a crack in your tail shaft casting - or something else in the image ?
                        thx,
                        Mark
                          • 43242
                          Hey Gerald,
                          Mark------
                          Well, it could be a crack. However, these kind of casting "imperfections" are very common on extension housing die/permanent mold castings. They appear like cracks but, usually, they are not. Testing would be in order, though.
                          • Mark F.
                            • July 31, 1998
                            • 1555
                            Mark------ Well, it could be a crack. However, these kind of casting "imperfections" are very common on extension housing die/permanent mold castings. They appear like cracks but, usually, they are not. Testing would be in order, though.
                            Hi Joe,
                            Yes. I see your point...
                            I have seen Sprue lines (which look like cracks when they get dirty and greasy) from imperfect dies/molds and or surface defects ...more so in aluminum castings vs cast iron.
                            thx,
                            Mark
