1957 Lower Plug Wire Shields - NCRS Discussion Boards
  • John P.
    • January 1, 2006
    • 162
    Hello, can anyone recommend a source for the right and left side "U" shaped plug wire shields that bolt to the block on a 1957? I believe the part numbers are 3733123 and 3733124. I have been trying to locate these for a couple weeks with no luck. I would consider a pair of used shields if they are in good condition. Does the full-size passenger car 283 use the same shields? Thanks so much in advance for any and all help, John
  • John J.
    • May 31, 1994
    • 59
    Re: 1957 Lower Plug Wire Shields
    Corvette Pacifica has a set online. Used set on eBay right now.
    • John P.
      • January 1, 2006
      • 162
      Hello John, I think I called them, and they were out of stock. I will call them Monday morning and check again. Thank you so much for your help, John
