1960 corvette rear door latch reinforcement plate rivets - how to install - NCRS Discussion Boards
  • Daniel S.
    • July 25, 2017
    • 117
    Hi ,
    I thought I was home free with getting the doors primed and ran into the rear door latch reinforcement plate separating from the fiberglass. On the brighter side I guess it is good it happened now and not after the car was painted.
    Does anyone have a good method of attaching the reinforcement plate with solid rivets after I repair the fiberglass?
    Dan
  • Terry D.
    • May 31, 1987
    • 2691
    Re: 1960 corvette rear door latch reinforcement plate rivets - how to install
    How was it attached from the factory?
    • Daniel S.
      • July 25, 2017
      • 117
      Hi Terry,
      It is attached with solid aluminum rivets. I just don't know a good way of mushrooming the rivet on the inside of the door. I can reach in there.
      Dan
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        Dan, 3/16" Pop rivets, then slightly grind the heads to flatten them. Fill with JB weld, sand flat, then the paint will make them look typical.
        (Here's your pdf image, now a jpg )
        • Daniel S.
          • July 25, 2017
          • 117
          Hi Richard,
          Great idea I feel like Im cheating .
          Dan
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11323
            Originally posted by Daniel Stairiker (63817)
            Hi Richard,
            Dan
            Dan, "Improvising" is another term when restoring something that the factory did on the line.
