1963 FI Unit - Build date before car was assembled - NCRS Discussion Boards
  • Keith W.
    • June 30, 1998
    • 375
    What is the acceptable date difference between the build of a FI unit - and the build date of the car ?
    I am sure - however I could have been drinking at the time - the acceptable difference is/was 6 months ?
    As always thanks Keith
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 927
    Re: 1963 FI Unit - Build date before car was assembled
    Keith, Please read the Judging Guide. There are some differences in the 63 units. If you go by the 6 month rule you may end up with a unit that is not correct for your project. What is the VIN range of your car? I might be able to give you some details to look for.
    Joe
    • Keith W.
      • June 30, 1998
      • 375
      Hi Joe thanks for the help
      Vin 30867S106710
      Approx. Jan 13th 63 build date
      FI unit info
      Serial # 3152 S or a 5
      Part # 7017375
      Hope that helps - Keith
      • David H.
        • June 30, 2001
        • 1559
        I am sure - however I could have been drinking at the time - the acceptable difference is/was 6 months ? As always thanks Keith
        Keith
        I think Joe's recommendation was to obtain a Judging Guide for your 1963 and follow that.
        As to six months, you'll see that reference re casting dates on engine blocks. That six months is an arbitrary criteria - typically, engine cases didn't sit around. As John Hinckley has noted, six months was so we would have cars to judge. (trying to find a replacement block within a couple weeks before your build would be problematic).
        Expected part numbers are going to be what is expected for your VIN range. That's why TIMJG is your reference.
        Dave
        • Keith W.
          • June 30, 1998
          • 375
          Appreciate your help Dave - Thanks
