Proper air cleaner base for aftermarket Holley - NCRS Discussion Boards
  • Justin S.
    • July 3, 2013
    • 305
    I'm seeing bases with disclaimers in ads that they will not work with aftermarket Holley's due to the rear accelerator pump.
    What will work for a 6210?
    https://www.forums.ncrs.org/showthre...er+base+holley
  • Justin S.
    • July 3, 2013
    • 305
    Re: Proper air cleaner base for aftermarket Holley
    Zip item #AC-58 worked.
    • Mark E.
      • April 1, 1993
      • 4602
      Good to know. Your profile shows you have a '70 LS5. Did this base fit over a spread bore Holley and provide hood clearance on a 454 with stock intake?
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Justin S.
        • July 3, 2013
        • 305
        Mark,
        I'm using a torker 2 intake which is approximately 1 3/4" taller than the stock intake.
        • Mark E.
          • April 1, 1993
          • 4602
          Mark,
          And the Holley is about 1/2" taller than a Q-Jet. So you're using a taller hood?
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Justin S.
            • July 3, 2013
            • 305
            Mark,
            My build is incomplete but yes I'm planning to use a taller hood.
            I also need an adapter for the square bore intake which will raise the carb by another 1/2"
            • Mark E.
              • April 1, 1993
              • 4602
              I'm not an expert, but know adapters cost power and space. You might be better off using a spreadbore intake or a square flange carburetor with the torker.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
