I see that Google already found the new forum and format:
New Forum
New Forum
Available stickers: Engine suffix code, exhaust tips & mufflers, shocks, AIR diverter valve broadcast code.Tags: None- Top
Re: New Forum
PatrickI see that Google already found the new forum and format:
https://www.tst.forums.ncrs.org/foru...cal-discussion
Expect ".tst," was just a test - as both were powered by vBulletin.
Dave
p.s. BTW how much time do you spend on Google?Judging Chairman Mid-Way USA (Kansas) Chapter- Top
Re: New Forum
Akan,
If you look at the Board of Directors meeting minutes in the back of your latest Corvette Restorer youโll see that John Waggoner reported that the current DB software is obsolete, and the current server is obsolete.
Gary- Top
Re: New Forum
I was just looking for a distributor rebuilder now that Don Baker retired.
In doing that, the new forum popped up.
FYI, I used Google images MANY times per day to explain anatomy to patients. I love it.Vice-Chairman (West), Michigan Chapter NCRS
Re: New Forum
I'm sure it's in testing stage right now.I logged into this new format, but I found it incomprehensible. I expected โlatest topicsโ to be chronological like like the pages of the current forum, but it was a seemingly random listing of past threads. What am I missing? Does it have a section of daily responses somewhere like we have here?
It looks like it's frozen in time from a few months ago.Vice-Chairman (West), Michigan Chapter NCRS
Re: New Forum
- Patrick Boyd,
click on the "Latest Activity"
- Patrick Hulst,
Yes it's a work in progress. What you see is the way it's going to look when completed.
Current TDB uses vBulletin 4, which is depreciated aka manufacture discontinued and unsupported. Upgrade is mandatory to keep the server healthy and working.
Gary
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Re: New Forum
- Patrick Boyd,
[ATTACH=CONFIG]123732[/ATTACH]
- Patrick Hulst,
Gary
Thanks Gary! I know what you mean as I just had to update some other software due to it being replaced. Good Luck and Thanks for what you all do in support! Steve- Top
Re: New Forum
Changing the back-end software and database is not an easy process. We only see the forward facing stuff, but a lot goes into the backend to make it work. Patience is the key here and I'm certain it will end up being at least as good, and more likely better, in many ways.67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569- Top
