Changing out the battery, I completely forgot to drain the radiator prior to removing the expansion tank and draining what would drain at the T connection. I do not have time to do a complete flush - guessing I may get air in the system and will need to let the tank "belch" air until it subsides? On a top-fill radiator, I would raise the front of the car to get the air positioned correctly. Any input on the drain order? I removed the tank as there was a lot of brown sludge when I siphoned the coolant out.
Thanks in Advance,
Fred
Thanks in Advance,
Fred
