1964 C2 replace rear pinion seal recommendations - NCRS Discussion Boards
  • George B.
    Infrequent User
    • January 19, 2024
    • 22
    Slight leak from rear pinion seal in 1964 Corvette. What are the watch outs in replacing the seal? What type of replacement fluid is recommended? Best way to measure to measure torque on nut so it goes back on the same?
    Appreciate feedback.
    George C2
    • 15706
    Re: 1964 C2 replace rear pinion seal recommendations
    For starters look at your 1963 Corvette Shop Manual for the seal change procedure and rear axle oil spec, and get back to us if you have questions.
    • Don H.
      Moderator
      • June 16, 2009
      • 2269
      See this older thread on the subject, in particular Post 3, and the link at the bottom of that Post.
      Good luck
      https://www.forums.ncrs.org/showthre...ht=Pinion+seal
      • Patrick B.
        • August 31, 1985
        • 2003
        Make sure you put some sealer on the splines or it will leak there and drive you crazy.
