65 - 66 Power Antenna Coating Material ? - NCRS Discussion Boards
  • Charles P.
    • November 1, 2021
    • 44
    Hi, Greg T retired from antenna restoriations so I have to do a bit of work on a 65 antenna unit. Thankfully, the drive cable and mast is intact but I will need to cut through the coating to open it. Does anyone know where I can find the coating material to recoat the unit after I finish repairs??? Thanks in advance...
  • Gary B.
    • February 1, 1997
    • 7079
    Re: 65 - 66 Power Antenna Coating Material ?
    Charles,
    The amber coating material that Greg Thompson used is listed in one of the postings in this thread:
    https://www.forums.ncrs.org/showthre...990#post941990
    Gary
    • Charles P.
      • November 1, 2021
      • 44
      Gary, found it...thanks!
      • Dave S.
        • August 31, 1992
        • 2930
        Charles.
        Share with us what you found on the dipping. I was unable to find anything mentioned in that thread. Looking to re-dip my rebuilt antenna.
        • Gary B.
          • February 1, 1997
          • 7079
          Dave,
          Posting #40 in that previous thread has this:
          dipseal
          • Charles P.
            • November 1, 2021
            • 44
            I called Dipseal and ordered the coating material today. They are located in Rockford IL. It costs $4 lb. They will sell to you directly. The challenge is that you need a deep pot in order to dip the unit so you need an ample amount of material. I ordered 15 lbs. I will post whether that is enough material to coat a unit.
            • Dave S.
              • August 31, 1992
              • 2930
              For those looking for that Amber look, Dipseal no longer makes it. The only product that Dipseal makes is Clear D-250. Let us know how the project progresses.
              • Gary B.
                • February 1, 1997
                • 7079
                Dave,
                Would it be possible to put dye in the clear Dipseal? It would take some experimenting mixing yellow, orange, brown, etc., to get close to amber.
                Gary
                • Dave S.
                  • August 31, 1992
                  • 2930
                  Originally posted by Gary Beaupre (28818)
                  Dave,
                  Gary
                  • John F.
                    • March 23, 2008
                    • 2424
                    Can't you just heat up the product and paint it on?
                    • Charles P.
                      • November 1, 2021
                      • 44
                      Dipseal says the diping process is very straight forward and you will get an even coat of material on the body. I think the challenge is getting that amount of material in a tall pot up to the correct 350 degrees; too cold and the material gets thicker. I plan to work on it next week and I will let you know how it goes. Dipseal says it can always be removed for a retry....
                      • Danny P.
                        • June 30, 2002
                        • 344
                        • Tim L.
                          Infrequent User
                          • September 4, 2013
                          • 13
                          Make sure you open or clean out the drain hole at the bottom. If you don't do that it will eventually end up filling up with water/moisture and have the same rusty and broken drive cable again. Best to use a golf tee and plug the hole before dipping. I also recommend that you lube the mast at least once a year with white grease, regular grease or even oil to keep the mast lubed. Extend it all the way up and down when you are lubricating the mast. You cannot over lubricate the mast within reason. Just make sure the excess does not run down on the paint!!
