Body Paint Stripping - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 271
    I am getting ready to strip body paint and looking for suggestions on good product to strip paint. Lots of pre-2020 advice but stripper paint formulas have changed. I have seen several products but they advise not to use on fiberglass.
  • Keith B.
    • December 1, 1991
    • 397
    Keith Burmeister
    • Walter R.
      • January 6, 2009
      • 271
      Re: Body Paint Stripping
      Looking for a product readily available that doesn't have the Methyl Chloride.
      • Robert P.
        • October 19, 2019
        • 318
        There is a product on the web called the strip club paint stripper , there are a few video's on u-tube looks like it works and no methyl chloride
        Bob Peckham
        • Brian M.
          • November 1, 1994
          • 128
          I used Citristrip from Lowes. I had 13 layers of paint to deal with, so several applications were required. The Citristrip can sit overnight without drying out for areas with heavy paint. I used a plastic razor blade to scrape it off after setting. It is a gel and worked well on vertical surfaces. I stripped one panel at a time, like a door or the hood, so a long working time was a huge benefit.
          i finished up with lacquer thinner when I got to bare fiberglass.
          The stuff does not burn your skin or have any noxious fumes.
          i started with the Aircraft safe for fiberglass stripper, recently reformulated, and found the short working time, fumes and skin burns were not going to work for me.
          Brian McIntyre
