1969 Corvette Tires for Judging - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 258
    I am finishing up a frame off restoration on a 1969 convertible October Build. The car came with the Original Spare Tire. The tire is a Goodyear Wide Tread with a Thin White Line. There is No other White on the Tire. Tire date is several months before build date.
    Does anyone know of a manufacturer of a Reproduction Tire. If there is Not a Reproduction, should I just buy 5 reproduction tires and Not use the Original. Any comments or advice is greatly appreciated.
  • Leif A.
    • August 31, 1997
    • 3645
    Re: 1969 Corvette Tires for Judging
    Steve,
    For judging purposes only, I would look into the tire shown below. I say "for judging purposes only" as this companies tires have a bad reputation for not balancing very well. They fit the "look" bill, though.
    The Goodyear Speedway Wide Tread F70-15 pinstripe whitewall tire is a special tire, designed to fit the classic Chevrolet Corvette. Specifically, this bias ply tire fits 1970, 1971 and 1972 Corvette, and it features a special two ply nylon construction, instead of the standard polyglas construction that other Goodyear tires featured during this time frame. The Poly/fiberglass construction didn't prove to be beneficial with the four wheel independent suspension beneath the Corvette, so Goodyear developed this tire without the fiberglass belting. The sidewall markings, .350-inch white stripe and tread pattern is authentic, and this non-belted tire is a proper fitment for your 70-72 Corvette.
    Leif
    • Reba W.
      • 938
      The spare tire does need to match the mounted ones. I would not remove it. Judges always like to see an original and that should be a 0 deduction.
