correct size sill plate screws - NCRS Discussion Boards
  • Garry B.
    • January 1, 1991
    • 666
    #31
    Re: correct size sill plate screws
    Steve, I can see where you might say that, but the shadows on the original makes it difficult to say for sure. If they are slightly different, how do we explain those who have acquired original sill plate screws and yet told the same thing I and others were, Bob Peckham being one of those.?
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
    • Gary B.
      • February 1, 1997
      • 7068
      #32
      Originally posted by Steve Alexander (2237)
      Just an observation, but the "height" of the cone on the repro appears longer than the original, which could prevent it from seating as deep into the sill plate as the original.
      • Gary B.
        • February 1, 1997
        • 7068
        #33
        • Ronald L.
          • October 18, 2009
          • 3248
          #34
          let me just say when we measured these back then, we used either 4x or 10x to confirm profile to spec. The repro sits too high, no shadows needed
          • Gary B.
            • February 1, 1997
            • 7068
            #35
            Ron,
            And what do you make of the experience Bob Peckham describes in his post #23?
            Gary
            • Ronald L.
              • October 18, 2009
              • 3248
              #36
              Gary
              That 80/82 is the underhead
              think of it this way 90 right angle. Just a little less
              the screw sits in the hole lower that what’s shown on the right
              • Gary B.
                • February 1, 1997
                • 7068
                #37
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  #38
                  Gary
                  its staring right at you
                  think 90
                  and don’t get tied to the edges
                  if all else fails classical Greek Architecture
                  if that fails
                  think what is a v form as it pertains to find the 90, squeeze a little
                  • Gary B.
                    • February 1, 1997
                    • 7068
                    #39
                    I’m giving the question of the 80 degree angle one more college try, since I still don’t get what you’re saying Ron. After this posting, I give up. Here’s an image with a line at the left drawn at 80 degrees from the vertical. Which I can see nowhere matching a comparable angle on either the original or the repro screw. Then I drew a line at 80 degrees from the vertical. The only place I can think that matches that angle on the screws is along the top of the head. In which case the 80 degree line matches both screws more or less comparably, but not perfectly in either case. The top of the screw heads seem to be slightly curved to me, not planar. So I still don’t know if the top of the head is where the 80 to 82 degree spec applies. But I can come up with no other location.
                    Someone else can continue this discussion if they have more to add.
                    Gary
                    PS The 80 degrees is not the under side head cone angle. That is around 50 degrees, as I clearly show in post 29.
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      #40
                      Gary you drew the lines here
                      Look again crossed lines
                      Forget past the intersection for a moment
                      They form a V shape
                      little less than 90 degrees
                      • David B.
                        • March 1, 1980
                        • 690
                        #41
                        BINGO! Your right on
                        • Gary B.
                          • February 1, 1997
                          • 7068
                          #42
                          • Michael G.
                            • November 12, 2008
                            • 2158
                            #43
                            The countersunk hole in the molding is supposed to have a cylindrical hole of a given depth before the hole becomes conical. It could be that the repro moldings have a slightly shorter cylindrical section than the original moldings, hence the top of the screw sits a bit more proud of the top surface of the molding than it did with the original molding.
                            If someone has both types of moldings handy, it’s a easy to measure, if only to rule this out.
                            Mike
                            1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
                            1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
                            • Alan D.
                              • January 1, 2005
                              • 2053
                              #44
                              Well hope this helps a little, have an original 4 hole 1964 sill pate and a 6 hole NOS sill plate (purchased 1970).
                              Measured smallest hole in each since the install of plate may have enlarged a little. Used a drill index to get size.
                              What I was surprised to find was that both plates had the same outside diameter of 0.339
                              You will need to enlarge to read the numbers, but diameter of 4 hole is 0.234 while 6 hole is 0.209
                              • Gary B.
                                • February 1, 1997
                                • 7068
                                #45
