For 1963 March build 340hp:
After reviewing numerous threads on mufflers (and blackout), I was unable to find where it mentions any visual or performance differences in the N11 off-road mufflers vs standard (other than the audible differences). My passenger side muffler has a small hole in the usual place from not driving the car regularly enough to heat up to normal operating temp and would like to fix before Otcober judging. The exhaust system has light surface rust but good otherwise.
Options?;
1) Patch hole with JB Weld and hope for the best?
2) Order new mufflers from ? Gardner, Corvette Central... (I tried Allen's but phone number in previous thread no longer works).
Quanta no longer has the asphalt-based blackout material so will use chassis paint in generous doses from Eastwood unless there are other recommendations.
Thanks in Advance.
Options?;
Thanks in Advance.
). I will take Duke's and your suggestions, add the blackout, and leave as is. Gonna get dinged for the non-welded pipe/muffler connection anyway.
