NAPA Fuel Pump Problem - NCRS Discussion Boards
  • Edward B.
    • January 1, 1988
    • 537
    Purchased new fuel pump at NAPA (Part No. B0186P). At home I tested the actuating lever for free movement prior to installation of pump and found lever to be so bound up that it would not move. Back to NAPA for a part return and tested the only other pump they had in stock before leaving store. Same result, actuating lever would not move. Counterman said he had heard of this problem before and that there was possibly a bad batch of pumps in circulation. It was too late in the day to get another brand pump so I'm stuck until next week. Has anyone else run into this problem?
  • Donald S.
    • August 31, 1996
    • 186
    Re: NAPA Fuel Pump Problem
    I'm far from an expert, but I don't ever remember being able to move the lever by hand.
    Don
    • Leif A.
      • August 31, 1997
      • 3633
      Don
      And, if you can, then the spring is either broken or has become dislodged.
      Leif
      • Owen L.
        • September 30, 1991
        • 869
        Don
        Well, at least I'm not alone in my babyman biceps!
        • Mike E.
          • February 28, 1975
          • 5139
