L78 Original Push Rod diameter - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 380
    My L78 broke a pushrod guide. Were the original push rods 3/8"?See photo.
  • Gary C.
    • April 1, 1998
    • 380
    Re: L78 Original Push Rod diameter
    If you look at Rockauto pushrods they mention, 3/8, 7/16 & 5/16"
    • Ray K.
      • July 31, 1985
      • 375
      Gary,
      Original push rods for L78 were 3/8. L88 motors used 7/16. Some engines ( low performance _ hydraulic cam ) beginning in 1967 used the 5/16.
      Ray
        • 43289
        Originally posted by Ray Kimminau (8917)
        Gary,
        Ray
        Ray and Gary------
        Yes, it's like this:
        ---all 1965-66 big blocks used 3/8" pushrods
        ---early 1967 L-36/L-68 used 5/16" pushrods (early= L-36/L-68 assembled prior to September 1, 1966)
        ---late 1967 L-36/L-68, all 1967 L-71/L-89, and all 1968-72 (except L-88 and ZL-1) used 3/8" pushrods
        ---all 1967-69 L-88 and ZL-1 used 7/16" pushrods
        ---all 1973-74 LS-4 used 5/16" pushrods
        In addition, the pushrod guide plates were specific to the pushrod diameters.
          • 15706
          Did someone "upgrade" to 7/16" pushrods, but NOT install the corresponding guide plates?
          • Gary C.
            • April 1, 1998
            • 380
            Thanks Joe.
            • Mark E.
              • April 1, 1993
              • 4610
              Gary,
              This requires more than replacing the push rod and its guide. Investigate why this happened and address root cause. The offset wear on the valve stem tip and broken push rod guide suggest the valve train geometry may not be centered causing lateral load. Worn or improperly installed valve guide? Bent valve? Broken spring? Piston contact??
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Leif A.
                • August 31, 1997
                • 3655
                Gary,
                Agree with Mark. Also, could be a lifter has come apart...been there, done that.
                Leif
                • Mark Z.
                  • March 1, 2004
                  • 51
                  Retainer, too!
