Trouble making the headlight bucket wiring harness connect - 1965 327 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    Having trouble making the headlight bucket wiring harness connect with LL reproduction front 1965 (327) front lighting harness.
    Has anyone else had trouble with the (three wire) connectors from the "bucket harness" not fitting into the harness which goes forward from the firewall, to the front of the body...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Robert P.
    • October 19, 2019
    • 306
    Re: Trouble making the headlight bucket wiring harness connect - 1965 327
    Tom yes i did ended up using my old plastic parts of the plug onto the new harness
    Bob Peckham
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Tom,
      Is it the Male & Female plastic connectors?
      Or the M & F terminals?
      I suspect it's the metal terminals. You may have to "relax" the female terminals a bit to get all 3 males to fit better.
      You can use a single male terminal(from your stash of loose singles), and test fit it into each female terminal. This will open them up a bit so they're not so tight.
      Rich
      • Jim S.
        Infrequent User
        • April 30, 1981
        • 8
        Tom,
        Me too.
        The male plastic terminal would not stay in place. What I found was that the repro harness used crappy spade terminals.
        The female terminal was a bit too small for the light harness (male terminal). Very awkward to make fit.
        I will leave out the name of harness manufacturer.
        • Gary B.
          • February 1, 1997
          • 7024
          • Tom D.
            • 2134
            I indicated with "LL" where mine came from at the top of this thread...
            Michigan Chapter
            Tom Dingman
            • Gary B.
              • February 1, 1997
              • 7024
              Ah. I see it now. Thanks for the tip.
              Gary
