Question On GM Wire Harness Tape - NCRS Discussion Boards
  • Larry E.
    • 1692
    Have a roll on the above; friction tape without adhesive. Any tips on using this
    type of tape to secure the ends?(So it will not unravel) I can see at the start of the application the tape
    can be secured by proper coil wrapping. At the other end there is no way to do this.
    Any idea's? Comments? Thanks in Advance>Larry P.S. Perhaps some "heat"
    applied to the ends???
    Larry
    LT1 in a 1LE -- One of 134
  • Alan D.
    • January 1, 2005
    • 2051
    Re: Question On GM Wire Harness Tape
    As I recall Larry, at the end you just loop it back and under the last few loops and pull tight.
    That will result in a small end not twisted around anything. (rather difficult to describe)
    • Dan D.
      • November 5, 2008
      • 1323
      Hi Larry,
      It was not friction tape. It was regular electrical tape, but without the adhesive.
      I believe the tape at the end of the harness was tied so it would not un-ravel. Look on the Lectric website - there may be a photo that show it better. Others may know too.
      Dan
      • James W.
        • December 1, 1990
        • 2669
        Here is a picture of the original rear wiring harness at the gas tank sending unit. you can see that it is tied. Hope this helps.
        James
        • Larry E.
          • 1692
          James West: Very nice ending of the tape. Don't know if I could ever do that. Is this done the way
          Alan suggests on above thread?? Thanks>Larry
          Larry
          • Gary B.
            • February 1, 1997
            • 7057
            • Larry E.
              • 1692
              OK;thanks to all for some idea's. Just have a small "patch" job on the starter harness
              between the Pass. Side firewall and Cylinder head. Hard to see from the top of engine.
              Larry
              Larry
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11345
                Here's are 2 original (a 67 and late '63) Headlight Bucket extension harnesses, showing the end loops tied back.
                A unrestored one from a '67
                A restored '63L
                Zoomed looped ends on the '63 pieces. It's a single knot.
                • Larry E.
                  • 1692
                  Update:OK;went well;looks good. Kinda lucked out as where the tape was ending was the clip
                  on the firewall where the wires go. So in essence the clip is holding the end of the
                  tape tight. Might add>Very Very tight in this area; not sure I could have tied the proper
                  knot. Larry and thanks to all
                  Larry
                  • James W.
                    • December 1, 1990
                    • 2669
                    Good to hear Larry, glad we could help!
