1972 Big Block Steering Pump - NCRS Discussion Boards
  • Anthony D.
    • August 31, 2005
    • 110
    Does anyone have a picture of big block pump, the guide states the neck is wider at the bottom than top and blends into the body, looking for a reference before I decide to rebuild mine or not.
  • Mark E.
    • April 1, 1993
    • 4607
    Re: 1972 Big Block Steering Pump
    Anthony,
    The 1970-72 JG has several good photos of the PS pump. I haven't looked in awhile but believe the neck base is a bit wider than its top but does not "blend into" to body per se. Check the photos.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Anthony D.
      • August 31, 2005
      • 110
      Anthony,
      - Unfortunately, I have the 5th edition, 6th has been sold out, perhaps better pics in that one, but in mine, there is no picture of a BB pump, only an up close picture of a SB.
      - That's what I'm looking for, it seems like the necks are pretty much straight on every picture I can see, but these are from the vendors, who don't specift BB vs SB.
      I'm trying to determine if mine could be original or a replacement as I want to fix the leaks, if it's worth while.
      Thanks!
      • Anthony D.
        • August 31, 2005
        • 110
        • Mark E.
          • April 1, 1993
          • 4607
          That looks like the right pump for a 70-72 BB. You also have the cast pulley which I believe is unique to these cars and hard to find.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Anthony D.
            • August 31, 2005
            • 110
            Thanks. I believe that to be the case. I’m confused about the manual that states the neck is wider at the bottom and has a smooth transition into the case. I can’t understand why there would be such a minor difference between the small/big blocks if that’s the case.
            I got a puller from Autozone to remove it and it’s not correct. Not sure what I need.
              • 43273
              Originally posted by Anthony Dusovic (44491)
              [ATTACH=CONFIG]123198[/ATTACH][ATTACH=CONFIG]123199[/ATTACH][ATTACH=CONFIG]123200[/ATTACH]
              Anthony------
              This is a correct power steering pump for a 1972 Corvette. Small block and big block pumps were the same for 1965-74.
              • Mark E.
                • April 1, 1993
                • 4607
                I gave the pump with the pulley attached to my rebuilder. If you DIY, please post a photo log of the process.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Anthony D.
                  • August 31, 2005
                  • 110
                    • 43273
                    Mark.
                    Will do. I got the pulley off last night. Easier than I thought, some kroil, wait 4 hours and use a standard puller.
                    It’s all apart now, I’m trying to figure out who makes a decent rebuild kit that doesn’t leak in a few months.
                    Anthony------
                    1963-74 power steering pump pulleys are not an interference fit on the shaft. Instead, they have a very slight tapered fit onto a very slightly tapered shaft and are retained by a special lock nut. However, they almost always "stick" to the tapered seat and must be broken loose with a puller. No special tool is required to install the pulley on the shaft.
                    1975 and later pump pulleys are a true interference fit on a non-tapered shaft and must be both installed and removed with special tools. No retaining locknut is used. All 1975+ power steering pump pulleys are of stamped steel construction; no cast iron pulleys were used for any Corvette application. The pump reservoir also changed for 1975+ power steering pumps.
                    • Anthony D.
                      • August 31, 2005
                      • 110
                      Anthony------
                        • 43273
                        Thanks Joe, The way mine came off, makes total sense with what you’re saying. As far as the pulley goes, is it a forged piece, since you said cast was never used on a corvette? Mine is not a stamped piece but looks correct compared to pictures I’ve seen. Sort of like a black phosphate type finish also. Thanks again!
                        Anthony------
                        Actually, no Corvette power steering pump pulleys were of forged steel material. Your pulley is a nodular cast iron piece. The same 2 groove pulley was used for all 1965-74 Corvette big blocks with power steering. A single groove, nodular cast iron pulley was used for most 1965-74 Corvettes with SHP small blocks and power steering. All other Corvette power steering pump pulleys were stamped steel.
                        • Anthony D.
                          • August 31, 2005
                          • 110
                            • 43273
                            Thanks again Joe. You had me confused when you said no corvette pulleys were cast. I assume that’s for 75 and later. Always great info here.
                            Anthony------
                            Yes, my statement that no pump pulleys were cast iron applied only to 1975+.
