C2, 3817827, strut rod bracket with welded-on shields - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2046
    FYI - just looked at a good example of an untouched 64 built around Oct/Nov 63.
    The rear end area appears to be untouched and does have the welded-on shields.
    A good example of their existence into the 64MY.
    It is also a radio delete car and did verify none of the grounds existed or holes being tapped.
    A good picture of this exists at
    https://www.forums.ncrs.org/showthread.php?43517-63-mid-64-(-)-strut-rod-bracket-heat-shields
  • Don H.
    Moderator
    • June 16, 2009
    • 2269
    Re: C2, 3817827, strut rod bracket with welded-on shields
    there was just a question on this on a 63 on the CF.. I posted this photo of my late Jan 64 coupe that still has them.. They would serve to block some heat from the exhaust pipes in very close proximity below.
