67 L79 spark plugs - difference between R45s and R45TS - NCRS Discussion Boards
  • Ara G.
    • January 31, 2008
    • 1108
    Re: 67 L79 spark plugs - difference between R45s and R45TS
    A gasket should be used with this type of spark plug, but I recall decades ago reading that not using a gasket would raise the CR a bit for more power. I recall trying it once, but found no SOTP difference, and didn't detect any significant leakage either.
    Back in the day I bought a box of 100 AC copper gaskets and used a fresh gasket with each plug change. This was when I was still using the OE AC 44 type and bought a spare set to swap back and forth because they would foul out in a few hundred miles of urban driving causing ignition breakup as low at 4000 RPM. Once I switched to the 45 cleaning was much less frequent, and I found that reusing the gaskets at least once was okay.
    I learned about spark plug heat range from an article in Corvette News, and the '63 Corvette Owner's Manual has heat range recommendations for various types of service including racing so I bought a set of AC 43 spark plugs for Kent hot lap days.
    Duke,
    Thanks for the reply. The AC 45 set i am looking does not have copper gaskets, it comes with steel gaskets. See pic attached. Assuming these would be fine? I also ordered a set of the Denso plugs. Having both sets is fine with me. As always, appreciate all the insight. ARA
      • 15672
      Yes, they should be okay to use. Are you sure those gaskets are steel? It looks like they might be aluminum to me. Check them with a magnet.
      • Ara G.
        • January 31, 2008
        • 1108
        #18
        Fellas, what should i gap the plugs to?
        • Leif A.
          • August 31, 1997
          • 3629
          #19
          .035 will get 'er done, Ara.
          Leif
