67 coil spring orientation - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 621
    There are excellent posts on the site relating to the correct orientation of the upper end of the front coil springs relative to a hole in the top of the tower. I thought I had my front end rattle situation narrowed done to the front passenger side spring and and in fact, that spring is not correctly clocked. I took some scope photos of both the left and right upper mounting which are shown below. In my case, the passenger side spring (same side as the noise) is definitely not correctly aligned and unfortunately neither is the driver side although no noise. The drive side is actually worse.
    Definitely have to deal with both side now and it is not a job that I will tackle personally. So I want to be prepared for any unforeseen circumstances in particular, whether or not the springs are correct in the 1st place.
    Is there a way to determine (on the car) if the springs I have are correct for my car (427/400HP convertible standard suspension)? The reason for that question is becasue the top of the spring on the drivers side is so far off I can't judge if it too large to fit correctly. The bottoms of both springs seat perfectly.
    Passenger side (different angle)
    Driver side - way off
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • 15706
    Re: 67 coil spring orientation
    The AMA specs that are part of the "vehicle information packages" you can download from the GM Heritage Web site have spring data like wire diameter, number of coils, free length, and other useful information.
    So measuring the wire diameter and observed number of coils should be a pretty good indicator of whether or not your springs are OE or OE equivalent.
    • Thomas S.
      • February 7, 2016
      • 621
      Duke - thank you. I had downloaded the entire AMA library when I bought my 63 and at the time, most of the AMA's were missing for Vettes 64 up through 67. Check back and the missing volumes are there. The wire OD is so I should be set. Section copied below in case anyone else has the same question. Also found another post on the site that references number of coils which was not mentioned in the AMA.
