Removing Paint inside Tail light housing - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    So long ago when Bubba painted the car or had it painted..."we" did not remove the tail light housings. I want to re-use them. I gave them an Evaporust bath which improved a lot but did nothing to the paint. Previously I had removed this same paint from wiper arms by cooking them good in Evaporust...which would likely work here but I fear unintended consequences, particularly trashing the rear gasket. The one in attached pic was entirely red on the inside and I have been chipping away at it with Swiss army knife and what not. It seems to want to chip and flake off but does take some scraping. This is leaving some mild/slight scratches in the galvanized finish but...meh...it is inside the lens anyway. It is however quite time consuming. Any thoughts on a better way? Acetone? Denatured alcohol.
    Separately, you will notice one of the studs snapped off halfway. These are much longer than needed so I think I can re-use this one. The rest I will soak longer in PB and or Kroil....and occasionally let the heat dissipate when removing nuts. Won't letting the heat dissipate reduce chances of breakage at least somewhat?
    Thanks!
    Keith
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
    • 11692
    Re: Removing Paint inside Tail light housing
    Acetone.
    Someone didn't remove the headlights (!) on Dad's car when they repainted it.
    Acetone worked great even 25 years later.
    • Keith M.
      • January 17, 2021
      • 695
      Acetone.
      Excellent. Application method? Brush or dab on and let it sit for a bit then scrape? Or does it need like an immersion soak? Does paint dissolve in the acetone? Not an area I have much experience in. Thank you.
      • Harry S.
        • July 31, 2002
        • 5344
        Your choice. The acetone will start to work quickly. Only metal in the acetone. If you soak, use rubber gloves and an old toothbrush to quicken the process.
          • 11692
          I just had it on a rag and wiped off the paint.
          I was wearing nitrile gloves.
          • Rod K.
            • 445
            Just to be safe, probably remove the gasket before applying acetone.
            • Donald S.
              • August 31, 1996
              • 186
              Those studs typically snap off. I drilled mine out and used JB Weld to secure bolts of the proper length and thread; unnoticeable once the lenses are in place. You'll need the length to attach the ground on the double nutted side. Don
              • Jeffrey S.
                • May 31, 1988
                • 1899
                Rear Tailight Restoration Article Vette Signal0001.pdfKieth,
                In 2019 I wrote an article for the Michigan Chapter magazine, The Vette Signal, on restoring the tailamp housings which included replacing snapped off studs. The files, one the written and one the photos is here (I'm not sure if this worked until I submit)
                Jeff
                • Mark E.
                  • April 1, 1993
                  • 4607
                  The four lamps on my '70 looked just as bad plus several studs were broken. I punted and acquired a set of NOS housings and lenses.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
