67 L36 with Power Steering and Factory AC - Replacing 2 hoses attached to reservoir - NCRS Discussion Boards
  • David J.
    Infrequent User
    • September 30, 1990
    • 25
    To replace the 2 power steering hoses attached to the reservoir/pump is it necessary to remove the reservoir, then the alternator bracket? if not, how do you reach the connectors attached to the reservoir?
    Thank you
  • Peter M.
    • May 30, 2013
    • 358
    Re: 67 L36 with Power Steering and Factory AC - Replacing 2 hoses attached to reserv
    David,
    Since no one else has offered anything I will take a shot. I also have a 67 427 with AC and PS. It has been a while but as I recall you can change the hoses from under the car without removing anything.
    It won't be easy and you may need some special wrenches (Line wrenches and maybe crows foot wrenches.)
    Kind regards
    • Gary J.
      • March 31, 1980
      • 1229
      Will also need to suck as much fluid out as possible. Remember the lines will have fluid in them also.
      • David J.
        Infrequent User
        • 25
        Thanks for the info Peter.
        • David J.
          Infrequent User
          • 25
          Thanks Gary!
