67' Corvette inside door panel hardware removal/re-installation - NCRS Discussion Boards
  • James C.
    Infrequent User
    • January 29, 2013
    • 21
    I have to remove the inside door trim panel of my 67' to repair and re-install the 2 window cranks but am now stumped when it comes to removing the circular "LOCK" knob... I assume it has a horseshoe clip behind the door trim panel, but how do I get under it with the clip removing tool without damaging the door panel?
  • Gary B.
    • February 1, 1997
    • 7070
    • James C.
      Infrequent User
      • January 29, 2013
      • 21
      Re: 67' Corvette inside door panel hardware removal/re-installation
      Thanks Gary, and I do have access to the page you've shared. So there is just enough margin of room to insert the clip removing tool from the bottom as you mention? If so, would you also blue tape the trim panel in that immediate area before using the tool for removal?
      • Gary B.
        • February 1, 1997
        • 7070
        You can borrow my tool if that would help. Or maybe some company makes one comparable in size to my homemade tool.
        Gary
        • Mark F.
          • July 31, 1998
          • 1598
          James,
          I did the same thing Gary did except I used an old credit card.
          trace the shape on one end
          cut it out (I think I did mine with scissors)
          buff off the edges (sprue) if any...
          it'll slide behind there and won't mar the vinyl
          I've done it at least 4 times on my '67
          good luck
          thx,
          Mark
          • Dean N.
            Infrequent User
            • 27
            James,
            when had to remove them, I use a "pick" that is use to remove O-Rings from their grove.
            I push on the door panel with my fingers to get just a little room to get the pick in their, I hook the clip, pull up and it will come right off
            takes about 30 sec and it is off........
            Dean Nelson
            1967 327/300 3-speed- Bowtie - P.V. - Duntov
            1971 454/425 LS-6
            1990 LT5 ZR-1 bought new
            • James C.
              Infrequent User
              • January 29, 2013
              • 21
              Many thanks gentlemen for all of your knowledge and experience! I just happen to have 2 old credit cards (each of a different thickness as well). At this point I'll try fabricating a "clip remover" and try my luck! Have a great day and thanks again!
              Jim Causley
              1967 327/300 M20 with Fact. A/C black over black htp.
              2006 Stingray convert
              2015 Z06 convert trip. black
              2022 stingray htp 3LT, Z51
              • Gary B.
                • February 1, 1997
                • 7070
                • David Z.
                  • April 1, 2002
                  • 182
                  Attached PDF has some tips for removing the "omega" (horseshoe clips).
                  Dave Z
                  Dave Zuberer
                  • Leif A.
                    • August 31, 1997
                    • 3654
                    Get an old T-shirt and cut a 1" x12" piece out of it. See-saw the strip of cloth behind the knob and the cloth will catch the clip and pull it right out. Additionally, the cloth will not mar the door panel. Easy peasy!!
                    Install the clip on the knob prior to re-installing...push the knob on the shaft and the clip will catch...done.
                    Leif
                    • Bill M.
                      • 1328
                      Use the o ring pick
