Which is correct? '63 UPPER A-ARM BUSHING RETAINER GM 9785742 - NCRS Discussion Boards
    • November 1, 1998
    • 145
    Retainer on left came off the '63, right is what I have for replacement PN 9785742...Thanks
    Found a second set, so now 2 to chose from
    Another pic with packages
    • 43273
    Re: Which is correct? '63 UPPER A-ARM BUSHING RETAINER GM 9785742
    [ATTACH=CONFIG]122883[/ATTACH]
    [ATTACH=CONFIG]122884[/ATTACH]
    [ATTACH=CONFIG]122885[/ATTACH]
    Jack------
    The original upper a-arm bushing retainer was GM #3710586. It was discontinued in March, 1977 and replaced by GM #9785742.
      • November 1, 1998
      • 145
      Thanks Joe,
      Found a picture of orginal so I guess the question now is which set matches the orginals best
        • 43273
        Thanks Joe,
        [ATTACH=CONFIG]122886[/ATTACH]
        Jack-----
        The one on the left side of your first photo is the original and of the original configuration. The one in your last photo, although rust-covered, is the same configuration. The 9785742, while completely functional, is not of the original configuration.
          • November 1, 1998
          • 145
          Thanks Joe, was beginning to wonder if any of the sets would be correct...jack
