Question For Our C2 Brake Experts - NCRS Discussion Boards
  • Larry E.
    • 1684
    Have question on brakes when car is in "Winter Storage" in Omni (Car Bag). 66 Corvette has
    manual brakes(No Power Brake car) that uses Dot#5 brake fluid. Car will be stored in a non-
    heated building in Illinois which means temps will vary from 100 To -10 Degrees for a 6 month
    period. Doing some research I believe that the seals in the brake system will shrink and expand
    somewhat (very small amount) when stored in this type of environment. Here is my question>
    Does anybody see a problem if I have the brake pedal pushed down(Not at maximum distance)
    during the whole 6 month period?? I have explained my problem on a previous thread so I am
    not asking for why I'm doing this but if it is OK TO DO THIS. THANKS IN ADVANCE>LARRY
    P.S. Thinking that a little applied pressure on the brake system will keep the shrinking/expansion
    to a minimum. Comments always welcomed. Thanks
    Larry
    LT1 in a 1LE -- One of 134
  • John D.
    • June 30, 1991
    • 875
    Re: Question For Our C2 Brake Experts
    I rebuilt my 67 calipers which are all sleeved with conventional seals and DOT 5 fluid 25 years ago and have had no problems. Unheated garage but we dont see -10F in the winter.
      • 15690
      ...odd thing to do. How about posting a link to the thread you are referring to.
      • Bill M.
        • 1328
        It seems to me that having pressure on the system while the seals shrink will cause fluid to surly leak out until pressure is relieved. I live in Dutchess NY where we reach +5* often and have had no problems with fluid loss.
        • Larry E.
          • 1684
          Search and bring up>
          "66 C2 DOT#5 Brake fluid "disappears" during Winter Storage"
          This will give you my unique problem from the start. Larry>>Thanks again for response
          Larry
          • Larry E.
            • 1684
            Anybody else for a comment? Has anybody tried this before? (Leaving brake system
            pressurized for an extended time?) I can see two ways for the outcome to be:
            1) Being pressurized would force more fluid out.(Like Bill's comment above)
            2) Being pressurized would force the seals to expand and make better contact
            thus; less fluid would be forced out.
            Thanks again>Larry
            Larry
            • Ronald L.
              • October 18, 2009
              • 3248
              • Larry E.
                • 1684
                [QUOTE=Ronald Lovelace (50931);950172]
                Larry
                • Patrick B.
                  • August 31, 1985
                  • 2000
                  • Larry E.
                    • 1684
                    Patrick: Thanks for the Reply. Getting back to my question> Do you see any problem with the
                    brake pedal slightly depressed when car is in storage for an extended time? (6 Months In Car Bag)
                    Do you think this will keep to a minimum the expansion/shrinkage of the brake seals to a minimum?
                    Thanks again>Larry
                    Larry
                    • Patrick B.
                      • August 31, 1985
                      • 2000
                      • Ronald L.
                        • October 18, 2009
                        • 3248
                        Patrick,
                        Yes I missed keeping the system under pressure for 6 months...
                        The systems were never designed for that type of use - will address later.
                        Second - read my post, I had 1980 vintage silicone - great stuff. Vette Brakes supplied, out of business a decade by the time I am looking for a replacement.
                        2015 vintage silicone - read the label - is very different molecules.
                        And it was about that time 2020 that Lose Star and others started to sticker their boxes with the Dot 5 disclaimer.
                        Those were the facts as of 2020, and I began to experience issues with seals using new Dot 5....2018-2020.
                        Larry - no reason given why one would need to keep under pressure. System was not designed for that use mode. Leakage, I would espect.
                        That where park brakes, wheel chocks, wood block, jack stands etc come into play...
                        • Bill M.
                          • 1328
                          I used a short 2x4 to hold my heater box in place while I installed the blower motor box on engine side. Is this how you will apply pressure to th brake pedal ?
                          • Larry E.
                            • 1684
                            Bill: NO; just will use a 12" >>"Paint Mixer Stick" between the Brake Pedal and the lip of the
                            instrument panel. This puts the brake system at minimum applied pressure. Thanks-Larry
                            Larry
                            • Larry E.
                              • 1684
                              Thanks to all the response; few final thoughts>
                              From Ron>Larry - no reason given why one would need to keep under pressure. System was not designed for that use mode. Leakage, I would espect.
                              RON>PLEASE PULL UP MY ORIGINAL THREAD ON THIS SUBJECT.(SEE ABOVE HOW TO FIND IT) I HAVE
                              A VERY UNIQUE WAY OF STORAGE. EG.>WHERE I LIVE/TYPE OF BUILDING/OMNI BAG STORAGE/THE
                              VARIANCE OF TEMP/HUMIDITY FOR 6 MONTH STORAGE. You will see why I do this in this manner.
                              Patrick:Thanks again for your input on this subject. Larry
                              Larry
