Brake Caliper Elastomer and DOT 5 - NCRS Discussion Boards
  • Mark L.
    • 561
    We are all aware several of the major brake caliper rebuilders warn against using DOT 5 fluid. Last year I conducted FTIR testing on several DOT 5 samples finding there is very little difference among the brands. Earlier this year Pat Boyd conducted an experiment on the elastomer. Both results were published on this forum.
    I recently had Pat's and my samples tested using an FTIR method. Attached is a more detailed explanation. Bottom line is the EPDM peroxide cure elastomers are not effected by DOT 5. I just rebuilt my calipers using the EPDM o-rings.
  • Gary B.
    • February 1, 1997
    • 7080
    Re: Brake Caliper Elastomer and DOT 5
    As did I.
    Gary
    • David H.
      • June 30, 2001
      • 1567
      Mark & Pat
      Thanks for your efforts sorting this out!
      Dave
        • 6960
        Mark, do master cylinder seals and rubber hoses come into play with Dot 5?
        • Mark L.
          • 561
          Ed,
          You can see on the attachment that two elastomer components from a M/C were also tested by Pat and me. Both appear to be EPDM and are OK. Gary B. provided these samples and may comment on the source of them.
          • Larry M.
            • January 1, 1992
            • 2703
            Interesting information..................
            Special thanks to Pat and Mark for their continued work on this issue. Lone Star and the other Corvette caliper rebuilders need to get their o-ring specifications and quality checks under better control. Hopefully this will occur soon.
            Typically orange color of o-rings indicates some type of silicone rubber. Silicone will definitely not hold up with DOT 5.......and may also have problems with the other DOTs.
            Larry
            • Gary B.
              • February 1, 1997
              • 7080
              • Patrick B.
                • August 31, 1985
                • 2017
