1970 spare tire lock issue - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    Wanted to see if I had a firestone or goodyear in there. Looks like someone snapped off the key in there. Need ideas. Looks like the rubber boot is original style. Hoping I don't have to destroy it
  • Mike E.
    • February 28, 1975
    • 5138
    Re: 1970 spare tire lock issue
    Dennis, unbolt the two bolts to the crossmember and that will release the whole thing. If you need to remove the boot, use a heat gun/hair dryer to soften it before trying to remove it. Good luck!
    • Dennis D.
      • March 1, 2000
      • 1071
      Thanks Mike. I thought about using a floor jack on the carrier and maybe create some slack in the lock bolt. Not sure if the lock would keep it from swinging out of the way. Your idea sounds easier
      • Gary B.
        • February 1, 1997
        • 7018
        gsb1966@comcast.net
        Gary
        • Gary B.
          • February 1, 1997
          • 7018
          PS Do as Mike says to remove the lock and bolt from the car.
          • Dennis D.
            • March 1, 2000
            • 1071
            I'm not positive it's a broken key. Hard to see in there with the cover on. Found a pic of a good lock. It has a block off I assume the key moves aside.(wishful thinking)
            • Gary B.
              • February 1, 1997
              • 7018
              • Gary B.
                • February 1, 1997
                • 7018
                • John W.
                  • December 15, 2015
                  • 61
                  • Bob D.
                    NCRS Shipping Data Report Manager
                    • April 30, 1996
                    • 788
                    Dennis
                    Steve Walker out of New Mexico may be able to help with your lock situation. He is an NCRS member and you could send hima email with questions.
                    Bob
                    • Tim S.
                      • May 31, 1990
                      • 704
                      Originally posted by Bob Demmel (27621)
                      Dennis
                      Bob
                      Agreed. His response may be delayed, as I believe he has left for Bloomington already.
                      • John F.
                        • March 23, 2008
                        • 2408
                        Spray with Kroil and try to pick from both sides with a dental tool if you have one or a very sharp ice pick. I have used and old ice pick for 0ver 50+ years on stuff.
                        • Jeffrey S.
                          • May 31, 1988
                          • 1882
                          Dennis,
                          Email sent.
                          Jeff
