Differential Crossmember Bushing - NCRS Discussion Boards
  • Jim W.
    • April 1, 2006
    • 228
    I think I got ahead of myself disassembling the rear suspension/crossmember. After removing the differential it seemed a straight forward task to take out the bolts, straighten the 4 tabs and pry off the crossmember which was not much trouble. Problem is now I can't get the bushings off (should have read the TDB first). Is there a good way to do this or should I put the crossmember back on, bend over the tabs, and pry the whole thing off. I'm concerned with breaking the tabs with too many bend, re-bending.
    The overall condition of the bushings is OK and maybe reusable- what y'all think?crossmember bushing.jpgcrossmember bushing 2.jpgcrossmember bushing 4.jpgcrossmember bushing 5.jpg
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: Differential Crossmember Bushing
    Jim, No, keep it off.
    It's a pain, do you have a Sawzall? I've found that to be the way. Just cut, cut, cut.
    Rich
    • David H.
      • June 30, 2001
      • 1559
      Jim
      If rubber is quite stiff, than a Fein Tool with sharp blade would work. (Fein tool those vibrating saws used to cut-off plaster casts, etc)
      Sharp blade (smooth edge -NO TEETH) slice through those heavy 3/4" rubber mats used on dairy farms like they were butter.
      If rubber is very flexible, won't cut at all - much like these vibrating saws won't cut flesh.
      Dave
      • Jim W.
        • April 1, 2006
        • 228
        Was also thinking, that if serviceable; maybe I just leave them there and tape off while I clean up the frame. Then put the crossmember back on. Is that feasible?
        thx, Jim
        • Jim W.
          • April 1, 2006
          • 228
          Well as luck would have it, I was able to gently pry it out. I think because the seat was still coated with black paint and the rubber fairly clean it gave way. DCM Bushing.jpgCM Bushing2.jpgCM Bushing3.jpgo these look like they are re-usable?
          Jim
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11363
            Great!
            Bit, if me, I'd replace them as they're cracked and very old.
            • David H.
              • June 30, 2001
              • 1559
              Originally posted by Jim Wampler (45572)
              Well as luck would have it, I was able to gently pry it out. I think because the seat was still coated with black paint and the rubber fairly clean it gave way. ...Jim
              Jim
              So... buying that lottery ticket?
              Dave
                • 15706
                Put a thin film of silicone grease on the cushions before installation. that way the cross member should come off without too much effort the next time it needs to be removed.
                • Jim W.
                  • April 1, 2006
                  • 228
                  Thanks guys. I'm not against buying new except the configuration is different having 8 tabs. I've read where some have cut 4 off to "appear" original style.
                  Jim
                    • 43277
                    Jim
                    Jim------
                    Keep one thing in mind: GM did not go to the "8 tab" version for some later PRODUCTION as well as all 1963-79 SERVICE because the 4 tab version worked just as well.
                    • Joseph S.
                      National Judging Chairman
                      • March 1, 1985
                      • 930
                      Jim, The entire frame carries a point total of 15. You would not see a deduction for replacement bushing on the rear end crossmember for some additional tabs. That is a minor deviation from the original design.
                      • Timothy B.
                        • April 30, 1983
                        • 5202
                        Jim,
                        That frame looks very clean from the pictures. Most folks don't get off that easy removing these bushings.
                        • Jim W.
                          • April 1, 2006
                          • 228
                          Yeah, I've been very fortunate. This was a So. Cal car sold in LA and all three PO's were around Mojave . Very little to no rust; and I haven't broke a bolt or needed to cut anything yet. Only thing left to remove from frame is A-arms. So far I'm able to reuse most everything.
                          Originally posted by Timothy Barbieri (6542)
                          Jim,
