1972 Seat Track to Floor Mounting Bolts - NCRS Discussion Boards
  • Owen L.
    • September 30, 1991
    • 895
    I've read a number of past forum posts about the changes in 1972 with the retractable seat belt but one detail has not been addressed very well.
    The rear outside mounting method is different than the other three corners. I believe pre-'72 there was a nut-plate at this location but it appears that '72 had a redesign such that the nut-plate was removed altogether, not just moved rearward to accommodate the retraction mechanism. This new more rearward location puts the mounting point inside the frame corner gusset with access through a triangular hole. The AIM shows changes on 3 pages but I don't see how the bolt tightens to anything.
    Here you can see that this corner has a #7 change note but it doesn't show anything in this spot.
    This page specifies a different bolt and a notation to drill a hole and refer to 1, sheet F29
    Sheet F29 shows the hole dimension for that bolt but nothing else.
    What does this bolt attach to? Is it a standalone nut? Do the '73 or '74 AIMs show this detail?
  • John S.
    • June 15, 2015
    • 508
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • Owen L.
      • 895
      Re: 1972 Seat Track to Floor Mounting Bolts
      Originally posted by John Sigmund (61302)
      Owen, pretty much the same in the ‘73 AIM. Yes it is a stand alone nut in that location, 5/16” coarse flange nut plus mine has a std 5/16” flat washer installed with the nut. Let me know if you need any further info.
      Thank you for the reply. Is this bolt merely a longer version of the other three, or could it be a different design? The bolts for the other corners have captured washers and flat tips. The possible bolt I have for the corner in question has a captured washer but with pointed tip and the threads appear much rustier than the others. (I'm not sure this bolt came from this location.)
      Do you know what it should look like?
      • John S.
        • June 15, 2015
        • 508
        Owen, you are correct. The bolt in that outer rear location is longer and has the pointed tip. That bolt measures 1 3/8” from the underside of the head to the tip of the point. The other three are 3/4” long measured to the end of the flat tip. All of the bolts have a recessed hex head and captured washer, see attached.
        • Owen L.
          • 895
          [ATTACH=CONFIG]122663[/ATTACH]
          Perfect! The web searches I did on the bolt part numbers show a couple different configurations for each bolt from different vendors, so I couldn't feel confident with my old ones. Thank you so much for the pic; it confirms I have the correct bolts.
