Correct finish for upper steering column bracket - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 688
    So got my column and upper bracket out. I know the bracket is tucked up way out of sight but I am a purist so wondering what correct finish would be. Attached pic is after an Evaporust bath...and it was pretty rusty. To me....I see no signs of paint so was gonna do a clear matte to help stave off future rust. Anyone have any insights on the "correct" finish?
    Keith
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • Gary B.
    • July 31, 1979
    • 926
    Re: Correct finish for upper steering column bracket
    These were natural, unpainted, unplated, bare metal.
    Look at using CRC SP350 ore SP400.
    Gary Bosselman
    • Keith M.
      • January 17, 2021
      • 688
      Gary Bosselman
      Thanks Gary. That CRC stuff looks pretty good. I do already have a can of clear matte so do you think CRC would be a better way to go?
      Regards
      Keith
      • Gary B.
        • July 31, 1979
        • 926
        Matt "Clear" leaves a film on the part. CRC SP350 will dry and look more natural. I use the SP400 on cast iron, more porous material.
        With that being said, that part is tucked so far up and out of the way, nobody is going to see it without being a contortionist. You could probably paint it pink and nobody would know except you and me. Use what you have.
        Gb
        • Keith M.
          • January 17, 2021
          • 688
          Gb
          Gary,
          Love that response. I considered pink for a moment but think I will use the matte that I have. For a part not easily accessible to recoat that might be better as the CRC products state they perform for a couple years. But am probably splitting hairs. I do thank u for the CRC info and am gonna pick some up. Getting the 400 as only diff between the two per CRC website is 350 is indoor only and 400 is indoor outdoor. The 400 should be great for parts that are accessible and can be recoated when needed.
          Keith
            • 11666
            Originally posted by Keith Michaud (67636)
            Gary,
            Keith
            The 400 can leave a much thicker yellow-gold coating. It's much "closer" to Cosmolene, if you will. I rarely use it, and would recommend the 350 as Gary did.
