67 Convertible wing window disassembly - NCRS Discussion Boards
  • Keith B.
    • December 1, 1991
    • 397
    I need to send my vent window frames out to be re-chromed. It has been many years since I have taken one apart. Can someone walk me through the steps. I remember you need to push down on the window to get the pivot out of the hole. The weather strip is in place and it seems to be hold things up. I don't want to break the pivot. Then how do I remove the window slide tract from the frame? There is one screw at the top of the frame that is accessible. I remember that there are two other screws that hold the channel onto the frame at the bottom of the frame. The fuzzy part (window tract) needs to removed to get to the screws. Do I need to drill out the rivets? the tract appears to be i good shape and i know there have been issues with reproductions being straight versus curved. How are they then reattached. Any pictures would be helpful. Thanks!
    Keith Burmeister
  • Jack M.
    • March 1, 1991
    • 1168
    Re: 67 Convertible wing window disassembly
    Keith- See if this LOF Manual is any help: CLICK HERE
    (from the 'Database of Restoration Documents' in the STICKY section)
