Another '63 upper A-arm question - NCRS Discussion Boards
    • November 1, 1998
    • 145
    What is Correct Novmeber 1963 Upper A-Arm Bushing retainer bolts, RSC, or these head markings and size?
    Thanks Jack
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 933
    Re: Another '63 upper A-arm question
    Jack, They are definitely a grade 8. That circle with the 6 lines is a good one. We have also seen A or M with 6 lines. I would think that an RSC could be correct also since this was a regular supplier to Chevrolet at the time.
      • November 1, 1998
      • 145
      Thank Joe,
      The markings on some of my baggies are not very readable from 20+ years ago when I disassembled it. Perm markers do wear off glad bags...live & learn...back to it
      Jack
      • Gary B.
        • February 1, 1997
        • 7078
        Jack,
        I’ve had the same problem with my black Sharpie writing disappearing from my baggies after 15 or 20 years being stored in a drawer with lots of bolt baggies. Fortunately, for many of the chassis bolts I removed from my ‘66 I made notes and created drawings of the headmarks. This is what I documented for the upper pivot shaft end bolts for my ‘66. I didn’t notate things that I could have, such as were the WB bolts on one side of the car and the RSC bolts on the other.
        Gary
          • November 1, 1998
          • 145
          Thanks Gary,
          Every little bit helps & will go into my notes.
          Jack
