Headlight switch - NCRS Discussion Boards
Headlight switch
  • Bill M.
    • 1328
    Headlight switch
    The headlights on my 67 will only rotate down by the switch they will not go up . I removed the switch and jumped the terminals and the same. I continuity tested the switch and I have continuity up and down. Withe the switch in place the cars ammeter moves when powering down but not up. Any ideas what I am missing ? Is there a fuse in the line ?
    thanks Bill
  • Harry S.
    • July 31, 2002
    • 5342
    Re: Headlight switch
    thanks Bill
    I could be wrong, but I think the wires for the motor use two bulkhead connectors. I think yellow is up and green is down. Pull the bulkhead connector and check for corrosion on the pins for the up wire. If you have a 67-wiring chart this will help.
    • Bill M.
      • 1328
      Thanks Harry I will check today
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11362
        Yes, Harry is correcto-mundo....
        I just hen-scratched a wiring diagram, showing what he said.... Rich
        • Bill M.
          • 1328
