Can I test a TI distributor magnetic pickup? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    I found the one in the picture in a box of parts a friend gave me. Since it was in a correct Delco parts box and does not appear to have been installed, I am assuming is NOS with some shelf aging.
    Is there a way to test this assembly?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • 15706
    Re: Can I test a TI distributor magnetic pickup?
    Check it for continuity. I don't recall the acceptable resistance range, but it should be listed in the '64 and '65 Corvette Shop Manual Supplements and subsequent Chassis Service Manuals.
    • Mark L.
      • 561
      I can tell you this item can get you to chase your tail. I had one that was fine until it got hot, much like a bad coil. Perhaps check continuity cold and hot would be the best way
      • Donald H.
        • November 2, 2009
        • 2586
        I was able to find an article on diagnosing problems with the TI distributor on the T.I. Specialties website. The resistance specification in the article was 500-700 ohms. I get 593 ohms on the one I have.
        Don
        Don Harris
        • Gary B.
          • February 1, 1997
          • 7046
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11328
            Yes 593 ohms is well within spec. That's a rare and desirable NOS piece.
            Go get Powerball?
            Rich
