C2 Voltage Regulator - NCRS Discussion Boards
  • George B.
    Infrequent User
    • January 19, 2024
    • 22
    Realized alternator was not charging battery. Diodes on alternator were bad. Rebuilt alternator and is putting out proper voltage, however still not recharging battery. Turns out voltage regulator is bad. Any recommendations on replacement voltage regulator? brand, type etc...
    GB
  • Harry S.
    • July 31, 2002
    • 5346
    Re: C2 Voltage Regulator
    I believe the original part number for a 64 is 1119515. As long as what you buy performs like the original you should be ok. But some of the new reproduction VR's may not be the same quality.
    I'd look for an NOS unit. If you do not care about date code, there are plenty out there, check eBay. You'll be in the $200.00 + range.
    Sealed NOS Delco Remy Voltage Regulator Camaro Chevelle Corvette 1119515 GM D635 | eBay
      • 6959
      George, you take the cover off regulator and clean the points, sometimes the glaze over sometimes, 220 sand paper or emery cloth will work. And while your there look at the electrical connector and test for power.
