66 C2 Washer Pump>Not Hearing Any Clicking When Activated - NCRS Discussion Boards
  • Larry E.
    • 1697
    Need help; judgement day is coming up fast. Trying to get all operations working. Everything Ok
    except for the washer pump. Not hearing any clicking when button is pushed. The wipers are working
    fine. Looking for some common problems to get fixed. No time to take everything apart. What are
    some simple things I should be looking for? Could the solenoid be jammed somehow? Need help
    quick. Thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 6956
    Re: 66 C2 Washer Pump>Not Hearing Any Clicking When Activated
    Larry, check your connections at pump. Also look to make sure you did not. Bend any electrical spades or pins. If that looks okay, then grab a test light or volt meter and test for power and ground. I believe that it’s a two wire connector so one is ground and one is power, you should be able to hook meter or light across the two terminals and push washer button.
    • Larry E.
      • 1697
      Edward: Where exactly is this two wire connector? Is it on the backside of the pump? Does someone have a picture
      where the spades are on the pump. Could not see them at 1st glance but will look a little harder tomorrow. Larry
      Larry
      • Larry E.
        • 1697
        After a little more research and looking I found out that my Washer Pump Harness is not even connected.
        I hope I can find the connector; not sure why is was not connected. Pictures Below. Larry
        Larry
          • 6956
          Yes the 2 wire connector is pump.maybe it’s on the other side of firewall? Or stuck behind motor?
          • Larry E.
            • 1697
            Edward: You hit the nail on the head. Thanks so much for helping me. Cleaned the spades and now works like a charm.
            I have all operations OK except for one which I will refuse to test. Yes it is the dreaded Cigarette Lighter without
            a fuse in the circuit. Do not want to play "Russian Roulette". Thanks again>Larry
            Larry
            • Leif A.
              • August 31, 1997
              • 3653
              Old expression "you can pay me now, or you can pay me later". Might as well test it now and see what you've got versus waiting for ops to have it (possibly) fail.
              Leif
              • Larry E.
                • 1697
                Leif:Will also refuse to test in the operation test and will take the point hit, Larry
                Larry
