C1 rear shocks - NCRS Discussion Boards
C1 rear shocks
  • Brian W.
    • September 30, 1990
    • 216
    C1 rear shocks
    Looking for rear shocks for my 54 & I found a set of spiral shocks part # 5516238 cant find any info on that number. Can anyone identify that number and will it fit my car?
    Brian
  • Mark S.
    • July 31, 1983
    • 668
    Re: C1 rear shocks
    50 to 55 Chev 3/4-ton truck rear shocks.
    • Brian W.
      • 216
      Re: C1 rear shocks
      Thanks Mark I think I will pass.
      • Brian W.
        • 216
        Re: C1 rear shocks
        I'm now leaning toward Monroe 5818 rear shocks. Has anyone used them or is there another option?
        • Dan L.
          • November 10, 2008
          • 85
          Re: C1 rear shocks
          On my ‘54 I’m using #5818 on the rear and #5751 on the front, purchased at NAPA. They work good for me.
          DAN
          • Brian W.
            • 216
            Re: C1 rear shocks
            Dan Is the 5818 the same shock that corvette central sells
            • Dan L.
              • November 10, 2008
              • 85
              Re: C1 rear shocks
              I don’t believe CC sells Monroe shocks.
              I purchased my Monroe shocks at NAPA at a better price than any shock the catalogs advertised.
              In my opinion, if you’re running a stock suspension, Monroe’s are all you need.
              DAN
              • Troy P.
                • February 1, 1989
                • 1284
                Re: C1 rear shocks
                If you are interested in judging, the keys to making the rear shocks appear correct even though they don't have the correct Delco stamping:
                1. Buy Delco shocks. Any Delco will lose less points. You can use new Delcos with the spiral or buy NOS vintage Delcos for 40s-50s passenger cars. The upper tubular shaft shield on passenger car shocks is too long but can easily be cut to the correct length. I can find you the length but seem to recall its about 7 1/2".
                2. Add the stone shields. Attach with JB Weld. Not sure if they are still reproduced but I have a pair.
                3. Paint them semi-gloss black.
                • Ed H.
                  • November 1, 1999
                  • 626
                  Re: C1 rear shocks
                  Brian, the following part numbers are 53-55, front-5520278, rear-5520279 right out of 53-55 parts catalog dated July 1955. If you desire originals suggest you contact Sokolowski in So.
                  CA. OR Newson in Texas.
